Results 1 to 10 of 10
Thread: Parts Recommendations -
  1. #1
    Default Parts Recommendations -
    Hey guys, recently broke my fixie. I need recommendations for a new chain (and perhaps chain breaker tool) and a new fixed hub - i don't want it to be flip flop - just straight out fixed would be fine. I'll probably need a new rim.. Vdeep might be the way to go?
    Failing that i'll probably haul it on down to the nice man grant at mc. Either way, i'd like to try fix it myself first so... recommend away...!
  2. #2
  3. #3
    Semi-Pro
    Join Date
    Dec 2008
    Location
    Sydney
    Posts
    1,624
    Default
    and when you say broke, what exactly do you mean?
  4. #4
    Default
    SE Lager!
    ...and the chain jumped off. I get the feeling the rear wheel wasn't far back enough and hence too much slack in the chain! Amazingly frustrating
  5. #5
    Default
    Amazingly Charlie, damn!
  6. #6
    Semi-Pro
    Join Date
    Dec 2008
    Location
    Sydney
    Posts
    1,624
    Default
    so you want a new rear wheel... maybe order in a deepV laced to a Velocity hub.
    as for chain you need a bmx style one..
  7. #7
    Default
    KMC BMX chain will do it Charlie, cheap as chips and come in many different colours too if you want that kinda thing.
  8. #8
    Default
    The boys have awesome recommendations (as per our telephone convo bro!)
    If you have to do it yourself I have the tools and you have the talent...together we can get crunk and rock out!
  9. #9
    Default
    Did you "f" up the hub or are just worried about it happening again dude?
    you can change the fixed gear/lock ring with a lockring tool/ chain whip which should be all you need to do? as for chain i don't trust the KMC ones :P the Surly has a sram and was debating swapping to a white kmc and didnt like them!
  10. #10
    Default
    right on the money lach-lan
    ill have a look into the lock ring tool too, i haven't really had time to really mess with it! Will post up how things go, thanks guys
Posting Permissions
  • You may not post new threads
  • You may not post replies
  • You may not post attachments
  • You may not edit your posts
